mbworld.org forumo platybese netiketai radau viena topika apie taip vadinama ECU reset. Po reset'o begiu perjungimas tapo zymiai tikslesnis ir greitesnis, bei dingo betkoks lagas, visa galia iskart po tavo koja :D Patariu ir jums pabandyt. Aisku jeigu jus visada ramiai vazinejat, tai gal ir neverta, dar ir raso sanaudos gali pakilt, bet pakenkt tai nieko nepakenks ;) Del sanaudu naturalu, nes dabar masina dar labiau provokuoja prispaust :D
1. Turn the ignition key to the on (not start) position (all warning lights on dash are on).
2. Press the gas pedal to the floor (pass the kickdown also) and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
The ECU reset procedure only erases the ADAPTIVE transmission & throttle settings.
http://mbworld.org/forums/c32-amg-c5...et-smokes.html
http://mbworld.org/forums/w211-amg/1...set-works.html
