Nereikia taip bijoti 3,5 M272 variklių bėdos, nes ji buvo ištaisyta 2009m.
M272 engines that were sold between 2004 and 2008 with engine serial numbers below 2729..30 468993 often show early wear of the balance shaft gears, requiring extensive repairs at a retail cost of over $4000. Applicable Models Early M272 and M273 ( Model Years 2004-2008) Applications: 2004–2008SLK350 2004–2008CLS350 2005–2008CLK350 2005–2008C350 2005–2008E350 2005–2008S350 2005–2008SL350 2006–2008R350 2006–2008ML350 2006–2008Sprinter 2004–2008 SLK280 2005–2008 CLS280 2005–2008 CLK280 2005–2008 C280 2005–2008 E280 2005–2008 SL280 2006–2008 R280 2007–2008 S280 You are fine if your number is higher than: M272 Engine Serial No. 2729..30 468993 M273 Engine Serial No. 2739..30 088611 |
Nu arba zmones nebekreipia demesio, arba as pasikeiciau :xx: arba kitaip - isauklejo :xx: |
Wzikai, as dziaugiuosi, kad tau sekasi, linkiu kuo didziausios sekmes!
Tu esi dar vienas puikus pavyzdys, kad turtam daug proto nereikia. |
kokios nuomonės apie šitą modelį ?
http://autoplius.lt/skelbimai/merced...s-4942454.html |
Laikas rodomas GMT +2. Dabartinis laikas yra 22:48. |
