w208 problema su elektra?
Šiandien išmetė tokia lentelę:
UNDERVOLTAGE CONSUMER DEFECTIVE! ir akumuliatoriaus ženklas. Manuale prie jo radau parašyta: It may indicate that the poly-V-belt has broken. Should this condition occur, the poly-V-belt must be replaced before continuing to operate the vehicle. Otherwise, the engine will overheat due to an inoperative water pump which may result in damage to the engine. Do not continue to drive the vehicle with this message displayed. Tai čia problemos su grandine? ar kame reikalas? |
su generatoriaus dirzu. Arba tiesiog mire generatoriaus sepeteliai
Laikas rodomas GMT +2. Dabartinis laikas yra 02:48. |
