W203 klaidos ir jų tvarkymas
Problema, kad kartais nuspaudus gazą iki dugno, auto labai lėtai greitėja, lyg gazas nebūtų nuspaustas. O kartais viskas gerai. Srauto matuokles atjungti nebandžiau. Tikrinant klaidas su DelphiCar (ne su STAR) gaunami klaidų pranešimai. Kokios jūsų preliminarios rekomendacijos tvarkymui: Diesel (611.962 - CDI 2 - MT/AT - 203.006/206/706) P1481 - Glow plug P0100 - Air mass meter (hot film) P1664 - Electronic heater booster Brake (ESP/BAS (Electronic Stability Program) - ESPMK25 (Electronic Stability Program) - MT/AT) C1038 - Engine control module; not identified/incorrect control module - Intermittent C1022 - CAN communication with the engine system is faulty - Intermittent C1210 - +30 voltage, below lower threshold - Intermittent Instrument (Instrument - KI203 - MT/AT) B110D - CAN; communication fault with control unit AAC pushbutton - Intermittent Climate (Climate control - KLA203 - MT/AT) B15A8 - Footwell flap actuator; left and right is blocked/stiff - Intermittent Gearbox (Gear selector - EWM203 (Gear selector) - AT) P2000 - Braking torque from the traction system over CAN bus; implausible Multifunction (SAM - Front (Signal Acquisition and Control Module - Front ) - SAMV203 - MT/AT) B1003 - Heating water circulation pump; open circuit or Short circuit to ground - Permanent B1040 - Control module ICM is not transmitting any data.If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check - Permanent B1029 - Control module AAC is not transmitting any data.If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check - Permanent B1012 - Left foglight - Permanent Multifunction (SAM - Rear (Signal Acquisition and Control Module - Rear) - SAMH203 (Signal Acquisition and Control Module - Rear) - MT/AT) B1072 - Right license plate lamp; short circuit or open circuit - Permanent B1056 - Center high-mounted stop light; short circuit or open circuit - Permanent B1089 - Fault in CAN communication with control unit Instrument cluster. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check - Permanent B1094 - Fault in CAN communication with control unit Right front door. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check - Permanent B1091 - Fault in CAN communication with control unit AAC pushbutton. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. - Permanent B1085 - Fuel gauge sensor, left and (or) right half of tank; short circuit or open circuit. - Permanent Multifunction (Upper control panel - OBF203 (Upper control panel) - MT/AT) 9021 - CAN: communication fault with IC (Instrument Cluster) - Permanent |
vaziuoji ir pasijungti star. kito varianto ner.
Buvo pajungtas STAR. Patvirtinta, kad problema su oro srauto matuoklę (P0100-001).
Papildomos klaidos dėl pakaitinimo žvakių, bet tai su trauka nesusiję (P1481-001 ir P1481-002). Dėkui. |
Laikas rodomas GMT +2. Dabartinis laikas yra 08:08. |
