Old 2009-02-25, 15:21   #1
Mukshas
Mukshas's Avatar
Užsiregistravo: 2009-01-10
Gyvenamoji Vieta: Spalding UK
Pranešimai: 787
Mukshas is on a distinguished road
Nusiųsti žinutę Mukshas per Skype™
Standartinis Mukshas S124 300TD-Turbo
Mukshas Mercedes-Benz S124 300TD Turbo ///MB1 Special Edition
Mano naujas pirkinys 90m sandeliukas S124 300TD -Turbo, sportline, darbo yra tiek prie isvaizdos tiek is tech puses, bet nedaug.... daugiau aprasymo bus veliau, kai pats pradesiu suprasti kas kur ir kaip
norejau coupe, o nusipirkau universala .... kartais pasitaiko taip gyvenime
kalpokai is senuku, bet vistiek graziau atrodo nei paprastos juodos skardos buvo
vasarai yra r16 borbet ratai kolkas, paskui gal dievas duos amg kokius 17
taip atrode mersiukas kai pirkau:
O toliau desiu foto kaip auto keiciasi.... Nulupta plevele nuo galiniu langu, + kalpokai niekas nepaneigs jog su kalpokais vaizdas geresnis
Juodos groteles priekyje, + MB zenkliukas melynu apvadu
+ ratai ir + mb1.lt lipdukas
VIN:****************
Model 300 TD TURBODIESEL
Delivery date 30.01.90
Dealer Hannover branch (220)
Interior fabric black+anthracite (071)
Paint
040 black (T) (с 01.01.1963)
Options
211 automatic limited slip differential (ASD) (с 01.07.1984)
rear axle with automatic limited slip differential (ASD)
240 outside temperature indicator (с 01.03.1982)
244 sports seats, front (с 01.07.1986)
260 elimination of model designation on rear lid (с 01.05.1968)
261 elimination of model designation V12 (с 01.11.1973)
281 trunk set, (280 SL)
steering wheel (390 mm) with sports design (с 01.03.1989)
534 antenna, mechanically operated, without radio set (с 01.01.1963 по 30.11.1990)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
585 Behr air conditioner and electric window lifters (front doors) (с 01.04.1970)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
650 sports chassis with 15-hole light alloy rims (с 01.12.1988 по 28.02.1993)
812 rear-mounted loudspeaker (с 01.11.1974)
951 rotating emergency flasher, front (blue light)
sportline (consisting of codes 65/0, 244, 281) (с 01.10.1989 по 28.02.1993)
mano MB pajuodavo moldingai
Borbet ratai parduoti - mersas laukia geresniu laiku
1989 300ce
Paskutinį kartą redagavo Mukshas; 2009-06-27 07:58 val.
Mukshas neprisijungęs   Cituoti
Old 2009-02-25, 15:28   #2
MB-190E 2,6l
MB-190E 2,6l's Avatar
Užsiregistravo: 2009-02-02
Pranešimai: 110
MB-190E 2,6l is on a distinguished road
Pradžioje rašė Mukshas View Post
Mano naujas pirkinys 90m sandeliukas 300TD-Turbo, sportline, darbo yra tiek prie isvaizdos tiek is tech puses, bet nedaug.... daugiau aprasymo bus veliau, kai pats pradesiu suprasti kas kur ir kaip
GRAZUS APARATELIS
idek vidaus foto
MB-190E 2,6l neprisijungęs   Cituoti
Old 2009-02-25, 15:37   #3
Mukshas
Mukshas's Avatar
Pranešimai: 787
Pradžioje rašė MB-190E 2,6l View Post
GRAZUS APARATELIS
idek vidaus foto
su vidum dabar reikia padirbeti, bet tuoj idesiu kaip buvo fotke is autogido, kitokios kolkas nepadariau, nes atrodo kaip nevalos masinos, nes taip ir buvo ! prirukytas ir dulkinas ir panasiai, buvau nuejes valyti siandien, bet rankos nusviro, nes slapdriba ir labai nemalonu buti lauke is vis
plevele nuplesiau, buvo aptamsintas galas, zinoma pasiliko labai daug prikibe tu juoduliu, tai dabar neturiu skiediklio, rytoj pirksiu, siandien tingiu, tai galas bus nuniauktas iki galo. Atradau kad veidrodeliai yra sildomi, bet elektra reguliuojasi tik keleivio puses .... pirma karta taip matau, siandien buvo MB jau pirmojo remonto - pakeista gofra, nuo siol malonus garsas viduje, ramiai vaziuojant maziau triuksmu nei menzininej masinoj
dar kai atsigausiu su pinigais kazkada butinai praleksiu per autolauzynus ir paieskosiu kokio nors vairo, nes su situo as nesivazinesiu, nors laikyti ir patogus pakankamai, bet daugiau nieko is jo gero
1989 300ce
Paskutinį kartą redagavo Mukshas; 2009-02-25 15:45 val.
Old 2009-02-25, 15:39   #4
2luxstyle
2luxstyle's Avatar
Užsiregistravo: 2009-01-14
Gyvenamoji Vieta: Jurbarkas
Pranešimai: 167
2luxstyle is on a distinguished road
super pirkinukas
2luxstyle neprisijungęs   Cituoti
Old 2009-02-25, 15:43   #5
driuliauskas
driuliauskas's Avatar
Užsiregistravo: 2009-01-05
Pranešimai: 2,751
na man stas salonas seniau buvo negrazus ir senoviskas, kaip dieduko marskiniai bet kai atradau priemones valymui ir atsigaivinau tai blin visai nieko pasidare. toks ryskiai juodas su sviesiu viduriu. tik ka galiu pasakyti-sniegas,vanduo ir cigareciu pelenai murzina nerealiai salona. reikia saugoti. na o mersas neblogas. kaip matau jau langai nulupti. kaip lipalus abu nuplesei ar tik didiji?
Old 2009-02-25, 15:49   #6
pucenas
pucenas's Avatar
Užsiregistravo: 2008-01-15
Pranešimai: 6,975
geras pirkinys o veidrodeliai tai jau jo vokietis matyt pagalvojo kad vairuotojo pasieki ir pats gali su ranka nusireguliuoti pas mane taip buwo irgi
Old 2009-02-25, 15:50   #7
Mukshas
Mukshas's Avatar
Pranešimai: 787
Pradžioje rašė driuliauskas View Post
nuemiau abudu lipalus, langus baigti tureciau rytoj damusti iki galo. O su kuo atsviezinti medzio apdaila? kiek zinau paneliu valiklis gali pazeisti laka ir jis patampa baltas. Beje pas mane tas salonas tikrai ne juodas, jis pilkas, kad ir kaip ji sveistum tikrai nepajuoduos, nes jis pilkas, bet tai nereiskia kad jo reikia nevalyti, jis dabar pasmirdes visas cigaretem (as nerukau, tai tik sustiprina sleikstuli) subeges visas kazkokias lopais ir tt....
pucenas - pas mane nuluzusi kojele reguliavimui jo, bei normaliai jis ten nesilaiko, tai buvo ispraustas gumos gabaliukas i pakrasti, per veidrodi reikia matyti kazka
1989 300ce
Old 2009-02-25, 15:57   #8
driuliauskas
Pranešimai: 2,751
pajuoduos. paimi ta valikly ispurski ir sepeciu sveitimo varai kaip uz tevyne. pas mane tas pats buvo. del langu nenaudok jokios chemijos. nusipirk scraper gremztuka toky su ypac astriu peiliuku nusivalo per kelias minutes. cia pasiskaityk isamiau kaip zmogui jis padejo.
http://www.mbclub.lt/index.php?optio...5&limitstart=0
del medzio tai patarciau naudoti mediniu baldu poliroli. rezultatas labai geras
Old 2009-02-25, 17:13   #9
Edgaras
Edgaras's Avatar
Užsiregistravo: 2008-07-17
Pranešimai: 4,093
tai kad kiek maciau W124 tai pas visus taip. arba vienas arba abu automatiniai. nemaciau tokiu kad butu abu mechaniniai.
manau cia pas mersus jeigu "mechaniniai" skaitosi tai tada buna vienas keleivio automatinis. o kai buna automatiniai tai tada abu tada jau ir tas "joystikas" buna biski kitoks - kaip pas W140
Old 2009-02-25, 17:17   #10
Mukshas
Mukshas's Avatar
Pranešimai: 787
katik nusigrandziau visus langus, uztrukau apie 5-10 min. pasiemiau akvariumo stiklu gramztuka i kuri dedasi britvute, tai labai lengvai nusivale, net nesitikejau kad taip lengvai valysis
1989 300ce
