Old 2013-12-30, 21:55   #9191
Krizoks
Krizoks's Avatar
Užsiregistravo: 2012-09-28
Pranešimai: 997
Krizoks is on a distinguished road
Melionai, taigi čia blevyzgos cia nesvarbu koks postas naudingas ar ne...
Krizoks neprisijungęs   Cituoti
Old 2013-12-30, 21:56   #9192
Pranešimai: 14,239
Pradžioje rašė Melionas View Post
Labai naudingas sis postas visam forumui.
Beje moderatoriai, ar galima pasalinti, temas ir postus mano parasytus is forumo?
Teoriskai galima, praktiskai sunkiai. Kam to reik?
Apple neprisijungęs   Cituoti
Old 2013-12-30, 21:58   #9193
Rupinasi kad darbo turetumet
Old 2013-12-30, 21:59   #9194
Krizoks
Krizoks's Avatar
Pranešimai: 997
Old 2013-12-30, 22:01   #9195
Pranešimai: 14,239
Nu ir vel knysle tavo kisama.
P.s
Apple vien temas pasalinti galima?
Galima, jei nori toliau, tai pm.
Old 2013-12-30, 22:01   #9196
Kolibris
Kolibris's Avatar
Užsiregistravo: 2012-09-15
Pranešimai: 1,984
Kolibris is on a distinguished road
o kam to reik? yra ir naudingu temu
Kolibris neprisijungęs   Cituoti
Old 2013-12-30, 22:32   #9197
pucenas
pucenas's Avatar
Užsiregistravo: 2008-01-15
Pranešimai: 6,975
Hankook Ventus S1 evo K107 A
315/35 ZR20 110Y XL
Michelin Latitude Diamaris
315/35 R20 106W
kas gali paaiskinti kas tas XL reiskia prie vienu buna prie kitu ne. aciu
Old 2013-12-30, 22:32   #9198
Turbut Extra Load, galimai sustiprinti kordai ir kietesne guma
http://en.wikipedia.org/wiki/Tire_code
"XL: eXtra Load; a tire that allows a higher inflation pressure than a Standard Load tire, which increases the tire's maximum load"
Old 2013-12-30, 22:37   #9199
Pranešimai: 14,239
Sustiprintas kordas, tiksliau padidintos apkrovos
RF stands for Reinforced
XL stands for Extra Load
RF and XL markings indicate tyres designed for load capacities and air pressures higher than those of standard tyres.
Extra Load tyres have increased load carrying capacity and achieve this by using higher inflation pressure. They have the same load carrying capacity as Standard Load tyres have at 35 psi, and have more load carrying capacity as the pressure increases - up to a maximum of 41 psi.
These tyres have a stronger internal construction which means they can hold more air pressure and therefore carry more weight
RF - 58kg more
XL - 70kg more
XL designations are predominantly used for car tyres and RF designation predominantly used for van tyres.
XL and RF tyres are however not interchangeable and mixing these two types of tyres could lead to poor handling.
If higher load tyres are originally fitted to a vehicle, the lower load version is not a suitable replacement.
Old 2013-12-30, 22:38   #9200
pucenas
pucenas's Avatar
Pranešimai: 6,975
tai man ant viliuko turi buti xl ar gali buti ir be jo? ar cia tas xl tipo tie runflat'ai?
