va greiciausiai bus tada taip kad tavo raudonas is mago (acc)pajungtas i pastovu pliusa o ne i nuo raktelio, manuale raso kad jei isjungi maga pastoviai eina tas demo jei raktelis pasuktas.
va istrauka is
http://www.scribd.com/doc/13597236/P...-Owners-Manual
Feature demo mode
The feature demo automatically starts when
you select the sourceOFF. The demo con-
tinues while the ignition switch is set to ACC
or ON. To cancel the feature demo, press and
holdVOLUME/MUTE. To restart the feature
demo, press and holdVOLUME/MUTE again.
Remember that if the feature demo continues
operating when the car engine is turned off, it
may drain battery power.
Important
The red lead (ACC) of this unit should be con-
nected to a terminal coupled with ignition switch
on/off operations. If this is not done, the vehicle
battery may be drained.
