Go Back   MB1 - Mercedes-Benz bendraminčiams » Foto Ir Video Galerija » Mercedes-Benz Nuotraukos
Old 2007-12-13, 18:13   #1
mb1
mb1's Avatar
Statusas: Administrator
Užsiregistravo: 2007-10-07
Pranešimai: 921
mb1 has disabled reputation
Standartinis CLK-Class (W208 W209)
mb1 neprisijungęs   Cituoti
Old 2007-12-13, 18:18   #2
mb1
mb1's Avatar
Pranešimai: 921
Old 2007-12-13, 18:19   #3
mb1
mb1's Avatar
Pranešimai: 921
Old 2007-12-13, 18:20   #4
mb1
mb1's Avatar
Pranešimai: 921
BRABUS CLK K8
Uncompromising Superlative Sport Coupe
BRABUS CLK K8: This badge stands for a superlative uncompromising sport coupe based on the
current Mercedes CLK. Powered by the new 550 hp / 405 kW BRABUS K8 eight-cylinder engine
with supercharger and equipped with numerous special technical and stylistic features the two-
door reaches a top speed of 325 km/h, pacing it squarely among the fastest street-legal cars in the
world.
At the heart of the CLK K8 is the supercharged BRABUS eight-cylinder engine with 5.5 liters
displacement. Extensive handwork was necessary to implant the compact engine together with a
generous intercooler and special heat exchangers for water, motor oil, transmission fluid and air
conditioning in the engine bay of the coupe. BRABUS also developed a dual-flow stainless-steel
high-performance exhaust system with metal catalysts and four chrome-plated exhaust tips.
Power yield of the supercharged engine – as the five-speed automatic gearbox and the BRABUS
rear locking differential operated exclusively with ARAL high-tech lubricants – is exceptional: The
V8 delivers 550 hp / 405 kW at 6,400 rpm. Even more impressive is the peak torque of 780 Nm at
just 3,000 rpm.
Performance of the BRABUS CLK K8 tells its own tale: 0 - 100 km/h in 4.1 seconds, 12.6 seconds
to 200 km/h and a top speed of 325 km/h are figures attained by only a select few street-legal cars.
The performance potential of the exclusive BRABUS coupe necessitates extensive modifications to
the suspension system. Excellent brakes are just as important as a powerful engine. BRABUS
equips the coupe with a newly developed high-performance brake system. The front axle features
6-piston aluminum fixed calipers with 375 x 36-millimeter vented and cross-drilled discs. On the
rear axle the system comes with 360 x 28-millimeter discs and six-piston aluminium fixed calipers.
The new brakes harmonize perfectly with the standard driving dynamics systems such as ABS,
AST and ESP. To make room for the large brakes and to be able to run tires capable of handling
the top speed of the BRABUS CLK V8 the two-door is fitted with multi-piece BRABUS Monoblock
VI light-alloy wheels in size 8.5Jx19 on the front axle and 10Jx19 in back. These attractive
titanium-look wheels with six double spokes are mounted with Michelin Pilot Sport Cup high-
performance tires in sizes 235/35 ZR 19 in front 265/30 ZR 19 on the rear axle.
The custom BRABUS threaded suspension was calibrated specifically to the 19-inch tires and
offers ride height adjustment as well as shocks with 9-stage adjustable bound and rebound. This
allows lowering the ride height by up to 45 millimeters and selection of individual suspension
settings. In addition BRABUS sport sway bars reduce body roll to a minimum.
The appearance of the BRABUS CLK K8 is characterized by aerodynamic functionality. The
custom-developed front apron features generous air ducts for radiator and front brakes. In addition
the BRABUS front spoiler has air outlets on both sides in front of the wheelhouses to better vent
the hot air from the radiators. An additional carbon spoiler lip also contributes to a maximum
reduction of lift on the front axle.
For optimal venting of the engine bay the BRABUS CLK K8 has a custom hood with integrated air
vents. The BRABUS rear apron features custom-tailored cutouts for the four exhaust tips of the
BRABUS sport exhaust system.
The interior of the BRABUS CLK K8 offers an excellent symbiosis of sporty functionality and
exclusive ambiance. The sport seats are upholstered with a combination of BRABUS Mastik
leather and Alcantara, and offer excellent lateral support in fast turns. Carbon applications in the
cockpit and on the foot pedals, as well as an aluminum shift knob add sporty highlights.
The ergonomically shaped BRABUS sport steering wheel with integrated steering-wheel shifter
with airbag offer optimal grip and is yet large enough not to block the driver's view of the BRABUS
instruments with a speedometer with its 360 km/h-scale.
Old 2007-12-14, 06:46   #5
mb1
mb1's Avatar
Pranešimai: 921
Sporting coupé: the Carlsson CLK-RS with 480 bhp on the basis of the new CLK 55 AMG
On the basis of the CLK 55 AMG, Carlsson has created an exclusive and sporting coupé that was to be seen for the first time at the Essen Motor Show in 2003: the CLK-RS with 480 bhp. Developed especially for all Clubsport fans, the CLK-RS is a guarantee of unadulterated driving pleasure.
Impressive power increase through a new supercharger system
The new supercharger system on the basis of the CLK 55 AMG was developed in close cooperation with Ogura Clutch Co. Ltd. Equipped with a highly efficient intercooler to reduce the temperature of the intake air, the supercharger is integrated into the engine unit in a technically and visually optimum position between the cylinder banks. The advantages of this high-performance supercharger, which is built under licence from Wankel, include high efficiency (up to over 70 percent), low-wear, quiet running, great durability, immediate response and low weight.
Engine output is increased to a powerful 480 bhp / 353 KW with maximum torque of 650 Nm at 2800 rpm, which greatly emphasises the sporting character of the CLK-RS. Top speed has been measured at over 310 km/h while acceleration from 0 to 100 km/h takes just 4.4 seconds and from 0 to 200 km/h a mere 14.2 seconds.
The complete Carlsson range for the CLK-RS
The complete, high-grade range of products for the Carlsson CLK-RS includes an aerodynamic package with front and rear aprons. Large air inlets for the intercooler and brake ventilation distinguish the front apron. A supplementary RS rear spoiler, RS front lip and (on request) RS rear wing bring about a reduction in lift at both the front and rear and harmonise with the exclusive and sporting look of the car as a whole.
Another aspect of the Carlsson range is height-adjustable Bilstein shock absorbers calibrated in accordance with the company's specifications. Permitting extremely high cornering speeds, these shock absorbers have 9-way adjustment for compression and rebound and can, therefore, be regulated for the complete spectrum of applications, i.e., from comfortable cruising mode to full race trim.
The CLK-RS roll bar offers additional protection and contributes to greater body rigidity. Ergonomically shaped Recaro bucket seats and the ergonomically designed steering wheel guarantee safety and comfort inside the car.
Another part of this exclusive range is Carlsson's complete sports exhaust system. Made of stainless steel with sport end silencers (2 or 4 tailpipes with oval trims), the system not only reduces back pressure but also generates a sound to delight the enthusiast's ears.
An impressive appearance: ultra-light forged wheels
The sporting and elegant look of the CLK-RS is rounded off perfectly by exclusive 16-spoke wheels. Carlsson recommends ultra-light forged wheels of the dimension 8.5 x 19" for the front axle, which weigh just 9.6 kg each (235/35 Dunlop SP 9000 Extra Load), and 10 x 19" for the back axle (265/30, Dunlop SP 9000 Extra Load).
Carlsson high-performance breaks
Breathtaking stopping is guaranteed by a Carlsson high-performance braking system (on request) with 6-piston, light-alloy fixed callipers at the front and 4-piston, light-alloy fixed callipers at the back coupled with ventilated, two-piece discs measuring 370 x 35 mm at the front and 344 x 28 mm at the back.
Paskutinį kartą redagavo Edgaras; 2011-03-06 13:44 val.
Old 2008-10-06, 13:34   #6
mb1
mb1's Avatar
Pranešimai: 921
Standartinis Mercedes Benz CLK DTM AMG Cabriolet
Old 2008-10-06, 13:38   #7
mb1
mb1's Avatar
Pranešimai: 921
Mika Häkkinen extends his fleet: The AMG-Mercedes DTM driver drives a brand new CLK DTM AMG Cabriolet. “After changing from the open Formula 1 racing car to the closed DTM saloon, the CLK DTM AMG Cabriolet is exactly the right car for quick trips around my home town Monte Carlo, or along the winding roads in the surrounding Maritime Alps” said the Formula 1 World Champion of 1998 and 1999. Apart from Mika Häkkinen the McLaren Mercedes Formula 1 driver Juan Pablo Montoya has also chosen a CLK DTM AMG Cabriolet; his team colleague Kimi Raikkönen has driven a CLK DTM AMG Coupé since 2005.
High tech derived from motorsport, racetrack handling dynamics, eye-catching design and utmost exclusivity – the new Mercedes - Benz CLK DTM AMG Cabriolet is not only the choice of prominent sportsmen, but also makes the hearts of other automobile enthusiasts beat faster. With its 428 kW/582 hp powerful AMG 5.5-litre V8 compressor engine, the newly developed AMG sports suspension, optionally available sports tyres and aerodynamics optimised in the wind tunnel the CLK DTM AMG Cabriolet, which is in a limited edition of 100, delivers a superlative performance: The AMG high-performance sports car accelerates in only 4.0 seconds from zero to 100 km/h, the highest speed is 300 km/h (electronically limited). This means that the new AMG high-performance car is the fastest open-top four-seater in the world.
The high demand for the CLK DTM AMG Coupé, which was also in a limited edition of 100 and was rapidly sold out, was the initial inspiration during the planning of the high-performance AMG Cabriolet. During development another model was also the most successful car in the German Touring Car Masters, namely the racing version of the Mercedes-Benz CLK with which Bernd Schneider became champion in the 2003 season. The equipment of the CLK DTM AMG Cabriolet is also orientated on the racetrack: AMG sports bucket seats with leather/Alcantara upholstery ensure optimal lateral support: The oval AMG racing steering wheel with suede covering and the AMG instrument cluster with 360 km/h speedometer scale lend the interior an unmistakable motorsport touch.
Technological transfer from motorsport
Alone the exterior design of the new CLK DTM AMG Cabriolet indicates the highest performance at the level of thoroughbred racing cars and attests to the transfer of top-class technology from motorsport: the deep-drawn front apron with large air inlets, striking wheel arch flaring, 19 and 20-inch AMG light-alloy wheels and the rear end in diffusor-look are reminiscent of the successful CLK racing touring cars from the German Touring Masters. Numerous body components are made of the high-strength and particularly light carbon fibre composite material CRP, for example the bonnet, doors, front wings, rear wheel arches flaring, the front and rear aprons as well as the rear aerofoil.
Superlative sports car performance
Under the bonnet is the supercharged AMG eight-cylinder engine known from numerous other AMG cars but here specifically redeveloped. There are modifications to the crankcase, pistons, cooling system, intake tract, supercharger and exhaust system. A 5439 cubic centimetres displacement provides the AMG V8 with a maximum performance of 428 kW/582 hp at 6100 rpm, and the maximum torque of 800 Newton metres is available at 3500 rpm. Instant response to accelerator pedal movements, powerful torque increase, exhilarating response and the unique V8 sound are the particular strengths of the AMG 5.5-litre V8 compressor engine which provides the new CLK DTM AMG Cabriolet with the performance of superlative sports cars. From 0 to 100 km/h requires only 4.0 seconds and the maximum speed is 300 km/h (electronically limited). No other open-top four-seater series production car achieves this. Racing feeling is also provided by the power transmission by means of the AMG SPEEDSHIFT five-speed automatic transmission: the five gears are changed by a brief pull of the AMG shift paddles on the steering wheel, the extremely short response times enable a particularly sporty and direct driving experience.
Newly developed adjustable suspension system and differential lock on rear axle
The suspension is also fully appropriate for the high-performance engine. It is a height-adjustable torsion suspension system such as is used in motor racing. The rear axle has been redesigned with completely new spring links and wheel carriers as well as reinforced drive shafts. Uni-ball joints on both axles have replaced the rubber elements to provide extremely precise handling. Optional traction is ensured by a multiple-disc limited-slip differential on the rear axle. The acceleration skid control ASR and the Electronic Stability Program (ESP®) have been adapted for the increased performance potential.
Optional Dunlop sports tyres for particularly good grip
Contact to the road surface is provided by optionally available sports tyres from DTM motorsport partner Dunlop; the dimensions are 255/35 R 19 (front) and 285/30 R 20 (rear). These tyres have a particularly good grip and are fitted on multi-piece AMG light-alloy wheels in double-spoke design in the sizes 8.5 by 19 or 10 by 20. With their filigree spokes they are not only strikingly attractive, but also ensure an effective brake ventilation. Perfect deceleration is also ensured by the newly developed AMG high-performance composite brake system with six-piston fixed-brake callipers at the front and four-piston fixed brake callipers at the rear.
Functional racing atmosphere in the interior
The interior of the CLK DTM AMG Cabriolet is characterised by a functional motor racing atmosphere with the astute exclusivity of a genuine AMG high performance car. AMG sports bucket seats of ultra-light CRP with leather /Alcantara upholstery provide the occupants with outstanding lateral support. The AMG sports steering wheel with its oval rim is covered in high-grip suede and gives the driver an excellent feel for the vehicle. The door linings, trim parts and other interior components are also of CRP. The redesigned centre console has a striking silver-coloured selector lever unit, starter button and four rocker switches for auxiliary functions.
Despite potential racetrack performance the CLK DTM AMG Cabriolet has all the virtues typical of any Mercedes model: everyday suitability, durability, safety, quality and standards of service for the most demanding requirements. Since May 2006 the first of the hand-built CLK DTM AMG Cabriolet, which is in a limited edition of 100, have been supplied to customers. The price in Germany is 277,820 euros (incl. 16% VAT). Prospective customers should not delay because the limited edition is almost sold out.
Source - Mercedes-Benz
Old 2008-12-09, 17:45   #8
cabrys
cabrys's Avatar
Užsiregistravo: 2008-10-08
Gyvenamoji Vieta: Telsiai
Pranešimai: 2,823
cabrys is on a distinguished road
Va cia mano numyletines Jauciu silpnybe jom...
A208
cabrys neprisijungęs   Cituoti
Old 2008-12-09, 17:47   #9
cabrys
cabrys's Avatar
Pranešimai: 2,823
A208
Old 2008-12-09, 17:48   #10
cabrys
cabrys's Avatar
Pranešimai: 2,823
A208
