Old 2013-04-15, 04:49   #1
Somesword
Somesword's Avatar
Užsiregistravo: 2012-03-15
Gyvenamoji Vieta: Plunge
Pranešimai: 4,548
Standartinis W220 Del tepalo variklio
Koki naudojat variklio tepala w220 ?
Man idomu pasidare, kaip reaguotu su pilna sintetika 0w40?
o kokie aplamai turetu but pagal gamintoja ?
Old 2013-04-15, 08:08   #2
SSS klase
SSS klase's Avatar
Užsiregistravo: 2011-03-14
Pranešimai: 2,390
SSS klase is on a distinguished road
5x30
Cadillac 4.6 l; MB V230; EX W220
Autosprendimai.eu
SSS klase neprisijungęs   Cituoti
Old 2013-04-15, 09:38   #3
Somesword
Somesword's Avatar
Pranešimai: 4,548
kazkaip keista. Gi w30 nelabai tinka musu klimatui
5W-30
Visasezoninė alyva
Žemiau -20 iki +20 °C
0W-40
Visasezoninė alyva
Žemiau -30 iki +40 °C
Old 2013-04-15, 21:30   #4
DTM
DTM's Avatar
Užsiregistravo: 2009-05-17
Gyvenamoji Vieta: Klaipėda
Pranešimai: 3,156
Tai cia tik SAE klampos indeksas, o kur gamintojo reikalaujama specifikacija ?
W140 S320
DTM neprisijungęs   Cituoti
Old 2013-04-15, 21:35   #5
Somesword
Somesword's Avatar
Pranešimai: 4,548
tai as meginu daugiau suzinot, nes biski labai zalias tame reikale
Old 2013-04-15, 21:41   #6
Ziuri specifikacija ir tada ziuri klampuma pagal oro temperaturas
Old 2013-04-15, 22:13   #7
Somesword
Somesword's Avatar
Pranešimai: 4,548
a) 229.3 was designed for use with a paper filter on gas engines with MY 1998 - 2004, and for a drain period of max 20K km (12K miles) It will not hurt to use a fleece filter here - just not necessary.
b) 229.5 was designed for use with a fleece filter on gas engines with MY 2005 onwards, and for an extended drain period of max 30K km (16K miles) However, it is also backwards compatible and could be used gas engines MY 1998 - 2004 with a paper filter, provided you do not exceed the 12K mile drain period. (a paper filter would disintegrate beyond that mileage)
is esmes galiu abu naudot ?
Old 2013-04-15, 22:43   #8
taip, tik jeigu naudosi popierini filtra, tai nevirsyti 20k km ridos, su medziaginiu galima sukti ir 30k
Old 2013-04-15, 23:45   #9
DTM
DTM's Avatar
Pranešimai: 3,156
W140 S320
Old 2013-04-24, 18:08   #10
Somesword
Somesword's Avatar
Pranešimai: 4,548
Ka jus manot apie sia alyva?
http://www.pirk.lt/mobil1-peak-life-5w50-4l/
Ar geriau?
http://www.pirk.lt/mobil-1-new-life-0w-40-4-l/
