Old 2016-07-07, 05:45   #1
mercedinis
mercedinis's Avatar
Užsiregistravo: 2015-03-26
Pranešimai: 2,588
mercedinis is on a distinguished road
Standartinis NTG1 video ziurejimas vaziuojant
Sveiki
Idejus dvd filma ji rodo, bet pradedant vaziuot vaizdas dingsta, lieka tik garsas, ten paraso kazka bla bla bla zodziu nesaugu
uzejus i "engineering mode" ir paspaudus "138" "147" neismeta papildomu funkciju kuriuose galim nustatit kad video roditu and tam tikru rezimu pvz kai pavara ant "P" ar uztrauktas rankinis ar nevaziuojant greiciau nei 10km/h
gal kas turi kokiu minciu ar varijantu kaip ijungti tas papildomas funkcijas, nejungiant staro?
prisegu nuotrauka
Paskutinį kartą redagavo mercedinis; 2016-07-07 06:16 val.
mercedinis neprisijungęs   Cituoti
Old 2016-07-07, 07:24   #2
Pranešimai: 8,552
Jau be staro neįjungsi, jei per ten neduoda.
Old 2016-07-13, 10:46   #3
mercedinis
mercedinis's Avatar
Pranešimai: 2,588
Sveiki
sendien nuvaziavau iki garaziuko kuriame metesi "star'as" intike radau info kaip per "star'a" pasikeisti, bet tikriausiai ten labai sena versija "star'o" nes pajungus skiriasi ka matai ekrane ir ko praso, gal yra norinciu padeti ? atvesti prie kelio? :-)
Cia info is intiko
"Enabling Comand DVD/TV in Motion (W211 W219) and other models instructions:
Mercedes W211 built until May 2008 is compatible with NTG1 Comand, while Benz built June 2008 onwards is fitted with a more modern NTG2.5 Comand. European NTG1 can play DVD and can easily be programmed to play video in motion with MB Star diagnostic system.
Equipment:
Mercedes Benz MB SD Connect C4 Star diagnostic tool
Dell D630 laptop
In Connect C4 Star diagnostic system (SDS) DAS Developer mode:
Install and activate the software (Software is pre-installed and activated if get the MB Connect C4 and second-hand Dell laptop)
Run a self test
Go to Control Unit
Find out and locate Audio, Video, Navigation und Telematik, hit F3
Ignore the system pop-up message for settings, hit F2 to continue
Select ESD warning, hit F3
Select COMAND /AUDIO
Select AUDIO 50 oder COMAND, hit F3
Select Entwicklungsdaten, hit F3
Select Steuergerate
Select Anpassungen, hit F3
Select Steuergerate
Select Anpassungen (Variantencoderierung), hit F3
Select HU Parameter, hit F3Pull down the line, you will see two options:
Driving speed is more than 0 kph
Driving speed is more than 10 kph
Change both statuses to TV/DVD enable to unlock
Click F3 to confirm coding
Now you be able to watch DVD/TV when car is in motion/driving your car."
o cia keletas nuotrauku nuo sendienos meginimu, gal kas turi minciu/pasiulimu.
Old 2016-07-13, 15:48   #4
rocky
rocky's Avatar
Užsiregistravo: 2012-07-11
Gyvenamoji Vieta: Lazdijai-Kaunas
Pranešimai: 2,510
rocky is on a distinguished road
Pradžioje rašė mercedinis View Post
Sveiki
Cia info is intiko
Equipment:
Dell D630 laptop
Run a self test
Go to Control Unit
Select Steuergerate
Select Steuergerate
Pacioj pirmoj foto ne ten nuejai del to ir neradai, reik eit i ->development data bei kiek matau lyg ir 2014 metu versija tai ne sena taviskiam pilnai uztenka
Mercedes bei Smart automobilių diagnostika su STAR,+37069323663 PM
Paskutinį kartą redagavo rocky; 2016-07-13 15:55 val.
rocky neprisijungęs   Cituoti
Old 2016-07-13, 15:59   #5
mercedinis
mercedinis's Avatar
Pranešimai: 2,588
sena turejau omeni kur info is intiko, reikes meginti kai daugiau info turesiu, neturiu laiko kiekviena karta vazinet ir tikrinti
Pradžioje rašė rocky View Post
Old 2016-07-13, 18:57   #6
Pranešimai: 8,396
Turetu atridyti taip, tik pas manes simuliacijoje viskas ijungta, nuo pat pradziu, ant galo kur rodo nulieka, pas taves rodys vienetuka.
sekmes.
https://drive.google.com/open?id=0B6...1I4RWRBUXpzZXM
Old 2016-07-20, 21:26   #7
Robis
Robis's Avatar
Užsiregistravo: 2010-11-16
Pranešimai: 5,002
gaila, kad ant ntg4 neina taip paprastai pasidaryti, kad navi veiktų įvedimas adreso važiuojant.. taip biesina kad stovint rekia
Robis neprisijungęs   Cituoti
Old 2016-07-21, 19:21   #8
Pranešimai: 8,396
specialiai tau.
https://drive.google.com/file/d/0B6q...ew?usp=sharing
Old 2016-07-21, 21:35   #9
Trojus
Trojus's Avatar
Užsiregistravo: 2015-05-25
Pranešimai: 220
Trojus is on a distinguished road
Gerai tai klausimas tada kaip nulauzti kad rodytu pastoviai o ne iki 10klm ar stovint? Koks comandas nzn 2011 w212 mersas
Trojus neprisijungęs   Cituoti
Old 2016-07-21, 21:48   #10
Pranešimai: 8,396
Pradžioje rašė Trojus View Post
dedi can filtra, arba perki cd, kainos panasios.
