Go Back   MB1 - Mercedes-Benz bendraminčiams » Techninė Pusė. Remontai Ir Kiti Techniniai Dalykai » C klasė » W204
Old 2020-07-09, 21:18   #1
hayko97
Užsiregistravo: 2020-07-09
Gyvenamoji Vieta: Panevezys
Pranešimai: 2
hayko97 is on a distinguished road
Standartinis ESP problema, help
važiuojant išmeta ESP klaida, auto praranda trauka, reikia išnaujo perkurt ir tada vel ok, bet po kurio laiko vėl tas pats, pasidariau diagnostika su carly gal kas supras kame bėda, 3 klaidas rodo.
00C2000 Fault: The supply voltage of the control unit is too low (undervoltage). / Fault: The supply voltage of control unit "N30/4 (Electronic Stability Program control unit)" is too low (undervoltage). The supply voltage of control unit 'N30/4 (Electronic Stability Program control unit)' is too low (undervoltage).
00C3201 Fault: Chassis CAN bus : One or more signals sent from control unit Engine management via the CAN bus is implausible. / Fault: No CAN message was received from control unit 'Combustion engine'. / Fault: One or more signals sent from control unit "Combustion engine" via the CAN bus is implausible. One or more signals sent from control unit 'Combustion engine' via the CAN bus is implausible.
00C2264 Fault: Fault in CAN communication with control unit Engine control module. / Fault: Control unit 'Combustion engine' is not coded or incorrectly coded. One or more signals sent from control unit 'Combustion engine' via the CAN bus is implausible. / Fault: Chassis CAN bus : Fault in CAN communication with control unit Engine control module. / Fault: One or more signals sent from control unit "Combustion engine" via the CAN bus is implausible. One or more signals sent from control unit 'Combustion engine' via the CAN bus is implausible.
hayko97 neprisijungęs   Cituoti
Old 2020-07-09, 22:29   #2
Pranešimai: 8,551
Gal normalią diagnostiką pasidaryk.
Old 2020-07-10, 12:38   #3
Pranešimai: 8,396
Jaigu OM646 ir dega obd spidometre, tai tipine beda. Jau nekarta diskutuota forume.
Old 2020-07-12, 00:24   #4
hayko97
Pranešimai: 2
Taip pas mane 646, gal galima nuoroda?
Old 2020-07-12, 13:38   #5
Pranešimai: 8,396
Pradžioje rašė hayko97 View Post
As tingiu ieskoti. Bet man ir nereikia.
Žymės
esp, w204
